what about if we have 6 subs we want to connect to one amp (subs being dual 4)
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
Guest beatitouttheframe
im lost here help me out i have been around beats for years now and guys are talking about ohms what gunna beat louder 8ohms or 4 i mean does more  ohms mean more bass?
what if i haave 2 8ohms subs and my amp will not do 8ohms stable? and would  8ohms be louder than 4?
Guest SyKo13
Not necesarily(sp) more power, but a lower resistance which means you're pulling out more power from the amp. (Correct me if I'm wrong ;)
SK
so if i had  2 8ohm woofers and my amp only did 4 max  would i be underpowering them?
wire them in parallel. connect both positives and both negatives and that would make 4 ohms. ur amp definitely can handle that.
ok cool but what if i crossed them over what would happen if i tried to run 8 would it kill the amp? and also whats gunna beat louder and deeper a 4ohms woofer or 8?
4 ohms cause its gonna get more power from ur amp. i kno some amps cant go down to 8 ohms. so u might wanna check on that. and what do u mean by "if i crossed them"???? ur box is gonna matter on what hits harder and deeper too. most 8 ohm woofers arent even available ne more now too.
so the 8ohm dossent make them anybetter than a 4ohm woofr and my amp has a built in crossover system what if i cross them...and i have a single port box...its fairly big and what would happen if i made the box bigger but only used the to woofer setup?    i need help with this yall asap
  • Who's Online   0 Members, 0 Anonymous, 1788 Guests (See full list)
