bigp_on_the_beat Posted June 13, 2010 Report Posted June 13, 2010 I have 2 Optima Yellow tops (1 installed as my starter 1 sitting around) and I can get 1 Kinetik HC1800 from a friend. My question is should I use the HC1800 as my starter and put 1 optima in the trunk or the Optima in front and the HC1800 in the trunk? OR HC1800 in front & 2 optima's in the trunk?? I have a stock 70 amp alt did the big 3 0/1 gauge. Planning on a bigger alt when the funds are right. Whats your suggestions?? or should I wait for the alt? No car at the moment. New system: 2 Skar Audio VVX-12s Crescendo bc2000d Carquest NGT battery (back) Deka battery (front)
Guest Posted June 13, 2010 Report Posted June 13, 2010 all your batteries, no matter how many you have, will be "starter" batteries since they will all be linked together in 1/0 gauge (which i hope you plan on doing). there is no point in my opinion to have 3 batteries on a stock alt since each battery will take about 10 amps to charge, thats leaving 40 amps for the REST of the car AND the amplifier(s). stick with 1 kinetic under the hood and save for an alternator, then get batteries after that. what amp(s) are you planning to power may i ask?
corey0928 Posted June 13, 2010 Report Posted June 13, 2010 Kinetic in the back yellow top up front IMO but x2 on what kranny said
bigp_on_the_beat Posted June 13, 2010 Author Report Posted June 13, 2010 all your batteries, no matter how many you have, will be "starter" batteries since they will all be linked together in 1/0 gauge (which i hope you plan on doing). there is no point in my opinion to have 3 batteries on a stock alt since each battery will take about 10 amps to charge, thats leaving 40 amps for the REST of the car AND the amplifier(s). stick with 1 kinetic under the hood and save for an alternator, then get batteries after that. what amp(s) are you planning to power may i ask? Thanks I figured that would be a better idea. The amp I have right now is a Audiobahn A2X600HQ Rack amp. Amp Specs click this I looked around for a H.O. alt for my car but not alot of companies make them for my 93 Camry LE 2.2L 4Cyl. I found a iraggi 180amp alt for my car but thats about it. No car at the moment. New system: 2 Skar Audio VVX-12s Crescendo bc2000d Carquest NGT battery (back) Deka battery (front)
