my friend has a 97 accord, standard, stock electrical with a BOSS 800 4channel amp on a boston acoustic 10 pushing like 400wrms. Without fail the subs cut out on a really low note or even just if he has the the radio up loud. I cannot figure out whats going on. we tried it with all the settings on zero, bass at -6 on the hu and it still cuts out. anyone have any ideas?
Could it possibly be a bad ground? We cant figure it out at all. I had this amp in my truck for my first setup on 10gauge power wire, bridged on all 4 channels and my gain up and I never had a problem with it cutting out.
Setup:
BOSS 800 4channel amp bridged at 2ohms leaving two channels open
8guage rf amp kit
one boston acoustic 10
stock electrical.
2002 Ford Explorer XLT
Front Stage: Crescendo CCX 6.5's
Rear Stage: ???
Two 15" Powerbass M154
Audiopipe AP15001d
Pioneer DEH-P5100UB
bad voltage drop or bad ground
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Just checked the ground, its fine. no problems their. Im guessing its a voltage drop but how much could it possible drop at only 400 watts if that because its a BOSS amp, Im not even sure its putting that out.
Rear Stage: ???
Audiopipe AP15001d
Pioneer DEH-P5100UB
Is it getting hot? Could be thermal cutout.
Well when I tried it in his car with all 4 channels bridged at 2ohms each, it got extremely hot. We tested that song hey daddy by usher and when the bass dropped really low it blew both the 15amp fuses, we replaced them with what he had laying around so now he has 2 30amp fuses in it. But with only 1 channel bridged it gets warm but nothing out of the usual.
Rear Stage: ???
Audiopipe AP15001d
Pioneer DEH-P5100UB
How did you check the ground? Explain what you mean when you say you checked it...
X2
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
He had it installed from best buy so I went in and found out where it was grounded too. Down to bare metal but it was loose, so I tightened it down. Should I move it entirely and check again?
Rear Stage: ???
Audiopipe AP15001d
Pioneer DEH-P5100UB
bridged at 2 ohms? that means each channel is seeing 1 ohm...not good. thats the reason its cutting out and overheating. wire it to a higher ohm load or get a better amp.
anyone else see the epic fail in this post??
never, EVER put higher amp fuses than what was originally in there...
but.... it is a boss amp... you technically got nothing to lose.... lol..
it sounds like an ohm load issue... check the sub wiring... im guessing its wired to 1 ohm ...
or could be really bad voltage drop... you could try to do big III and see if it helps...
personally i say replace the amp...
is it SVC or DVC subs? pics of wiring could be helpful. of grounds too
My first truck... My first Real build...
*Update 8/9/10 DC Power 270xp Alt is In!!!*
1997 Toyota T-100 DC Level 5 18" in a T-line
Everybody wants their system to be....
1. Cheap
2. Reliable
3. Loud
...you can only pick two.
micahmye hertz pack
  • Who's Online   0 Members, 0 Anonymous, 1619 Guests (See full list)
