Okay.. so what amp should I get? I mean they were hitting pretty hard.. I just want some bass lol. It was working fine when I had a 1100watt boss amp but I sold that and got this.. so lmk please!!
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
umm i would say like 50 or 60 amp fuse
Introduce a no fat chicks in the whip rule.
Im gonna have tech force make up a sign that says that and put it on my car lol
So they were hittin much better with the boss 1100 wired the same? Try wiring at 4 ohm series/parallel like the second option here http://www.the12volt.com/caraudio/woofer_configurations.asp~Q~2~I~42 bridged (+from one channel and -from the other)
An Audio Technix 18" Strato on a Kicker KX120.2
My Youtube Bass Vids
Updates When Possible...
I've bought from JBurt09, OrionStang, bcpballer64, LoudNLow931, audioman21, and CJ18 from here (as refs)
Okay but I thought ur not supose to but a higher fuse?
And well they were hitting hard but I havnt even been able to turn these up cuz when I do the fuses blow. How would I wire them like that? The diagram is confusing to me.. I have the speakers in a box w/ termanals.
Team Subsonic Lows
:/ ok I'll try and put in words, give a couple of seconds
Edit: your amp should have 4 speakers connections right in this order probably: +,-,+,- from the first + on the amp you're going to run a wire to one + on one sub and then from there to another + on the other sub. Then from the 2nd - on the amp you're gonna run a wire to the - opposite of the + on the first sub and then from there to the similar - on the other sub. Then you're gonna connect the remaing +&- on the first sub together and the +&- on the second sub together and then that's it, you should be set
Edited by 7jezuz7
You post worthless information. Every single time.
I just noticed those posts got the op nowhere
Edit: and now these two haha
Edited by 7jezuz7
okay but how do I do thios thru the termanals on the box? thats what i dont understand..
Team Subsonic Lows
  • Who's Online   1 Member, 0 Anonymous, 986 Guests (See full list)
