will box (freq) be lower if i pull the subs out and go motors up
yes. your basically taking away the dis. of the subs. so if you can get the cuft of your box before dis. and that is how many cuft you would have. more air space is lower tuning. and yeah they would run cooler.
i think they sound like poop inverted. looks cool and all but i wouldnt do it.
Why like poop? they sound the same for your information.
Yes dude, the internal space will increase the amount of cubic feet your subs take, for example if the subs are 0.15 c/f then you´ll increase 0.6 cubic feet, YES i think you´ll pound the lows a little bit more because you´ll drop the tuning maybe a couple of hertz because those subs take some internal space...
Depending on your system and configuration it can change the tuning of your box, but not enough for you to notice any audible difference. If anything you might hear mechanical noise from the woofers. When I had my level threes inverted I could hear a very quiet buzzing and tinsel lead slap was noticeable on some notes.
DC AUDIO
06' Lancer
And then you also add the added airspace from the cone.
EDIT: oops Mr. P already said that
Edited by mporettim
  • Who's Online   0 Members, 0 Anonymous, 909 Guests (See full list)
