kogwanted Posted June 21, 2010 Report Posted June 21, 2010 ok so my subs were smelling weird when i was beating and then i adjusted my amp and then it still smelled a little bit but not nearly as bad as before is it ok if its just a little bit
tigolbity Posted June 21, 2010 Report Posted June 21, 2010 ok so my subs were smelling weird when i was beating and then i adjusted my amp and then it still smelled a little bit but not nearly as bad as before is it ok if its just a little bit usually subs smell when they get hot. when they get hot they will blow maybe feel your subs next time to see if they are hot. if they arent hot it could be something you used on your box. could even be your amp if its getting to hot.
kogwanted Posted June 21, 2010 Author Report Posted June 21, 2010 hmmm my amp never gets hot but my subs do get a little hot tho
