single 4 ohm subs to 1 ohm
i know how, just wondering if it would cause problems
yes or no?
Edited by tigolbity
how many are there?
edit you will need four of them if you were to try its like haveing two subs that are dual 4 if you connect two Voice coils you get 2 ohm then once you connect the other two you get a 2 ohm load then connect the two subs for a 1 ohm load
Edited by TeejayBee
how many are there?
yes i have 4,
and i have a question about my box. its tuned to 46hz (not on prupose lol, just made a box that looks good)
anyways, would i make my port longer to get it tuned lower? or would i shorten it?
Link to said port calculator
http://www.stevemeadedesigns.com/board/topic/38791-torres-box-tuning-calculator-updated-310/
pics of said GREAT looking box???
If your amp can handle a 1 ohm load and your cars electrical is strong enough them you shouldn't have any problem wiring them to 1 ohm
Edited by 7jezuz7
An Audio Technix 18" Strato on a Kicker KX120.2
My Youtube Bass Vids
Updates When Possible...
I've bought from JBurt09, OrionStang, bcpballer64, LoudNLow931, audioman21, and CJ18 from here (as refs)
ugh youd have to use a box tunner which you can find on the site here just look it up and if im correct you have to make it shorter
the calc i use says i need to make it longer
i go to the12volt.com
"Calculators, Charts, Diagrams"
scroll down, click "Volume Calculator - Rectangular/Square Enclosures"
scroll up, its right above the box volume calc for the spuare enclosures
my port is 1.5"wide x 17.5"tall x 9"long
and i have 1.8 cubes
Edited by tigolbity
lol i didnt say it was GREAT, its my first box ever
m_3786e88479ad4cedabba164197d2ded3.jpg[/img]
m_72f52f9ebfa1464c9694a3d5539962e3.jpg[/img]
100_3304.jpg[/img]
Longer port is lower tuning.
Remember the longer you make your port the smaller your box will get
ok well help me with my new post please
also in my other post please tell me what setting to put my DMM on plase
Is the 1.8 cu ft (gross internal volume, I guess) box for four subs? Hope that is enoough, man.
Don't forget speaker displacement (port was mentioned earlier) when solving your net cu ft.
7Jezuz7 nailed the first question.
Stetsom 11K2d
6-12" DC XL's
8 batts
Ohio Generator alt
2 punch 400's, 8 goldwood 6.5's, 4 selenium st200's
2010 MECA AS1 champ 146.7
Team DC I'm on the wagon, driving a wagon!
'90 Camry Wagon
155+ on music
member of MECA, FCBC, and IASCA
