JZeFF Posted June 23, 2010 Report Posted June 23, 2010 Alright, so.. whats the best way to screw the pieces together without them splitting? I already pre-drilled and counter-sunk the bottom/top, and front/back pieces.. Should i liquid nail all of the pieces together, and then drill through the pilot-holes into the untapped pieces of wood? What is the easiest way to do this? Pioneer x930 bt Rockford t2500 bdcp 18" nightshade v1 DC audio 175.4 RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon) 3x XS power D2700's Knukonceptz 0awg all around
n8ball2013 Posted June 23, 2010 Report Posted June 23, 2010 if you dont want the wood to split you need to stay close to the center. pre drilling helps alot THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
JZeFF Posted June 23, 2010 Author Report Posted June 23, 2010 if you dont want the wood to split you need to stay close to the center. pre drilling helps alot Yeah, i kinda figured they would all need to be predrilled... i just know thats going to be a pain in the ass and hoping there was some way around it. Thanks N8 Pioneer x930 bt Rockford t2500 bdcp 18" nightshade v1 DC audio 175.4 RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon) 3x XS power D2700's Knukonceptz 0awg all around
gumbysmoke Posted June 24, 2010 Report Posted June 24, 2010 i like to use a brad nailer, it's alot faster, and in conjunction with Titebond II, really strong. If you're OCD you can put like 1000 nails in that bitch in the matter of minutes. If you're using screws, pilot hole drilling should be all you really need to do to avoid splitting. 2001 Oldsmobile Alero 15" Fi BTL firing into cabin sealed from trunk (trunk wall) 8" interchageable flared aeros 4.8ft^3 box tuned to 34hz 2 AQ 1200's strapped (comming soon) Wiper flexage on only 1300 watts.. Link to my build.
