SUNDOWN, Dat, all in a trunk...
See... The way that EQ works, you connect the RCA from the "front" channel on the radio to the input on the EQ. The signal that the EQ receives needs to be a full range signal... So if I were to set the HPF on the headunit I would not get any bass output to the subs... Am I wrong?
maybe thats how you are supposed to set it up but I've always thought that the EQ is supposed to be for fine tuning of what is already present meaning you set all your settings in your deck the way you like then fine tune it with the EQ
I've always had defeat off on my Alpine and set the bass to +7 because it effects the subwoofer as well.. treble at -4.. HPF at 80hz.. bass engine centered around 60hz with the bandwidth set to 4 and treble set to 12.5khz with no problems
how high are the dials set on your EQ.. mine are turned up just barely past 12 oclock
as for the 7v preout that is max preout just like your amp if it were to be in a retail store would say 2000 watts peak
general rule of thumb for that is divide it in half for RMS and you would get 1000 RMS
just like 7v preout max.. divide in half is 3.5v preout
just a little upgrade to the 2v preout on your Alpine
as for the mids and highs let me know if your HPF is still set to 150hz after you turn defeat off and set everything in the deck
I guarantee you will hear a noticeable SQ difference when you get everything set through the deck.. much warmer sound
Wouldnt be thehoe92 without teh purple
Went out and recorded a video earlier this morning of the overall system...
After the 6 minute video I felt the Amps, just for shits and giggles felt pretty warm... Had an hour car ride ahead of me... Turned the amp gain all the way down, turned the remote knob down all the way, turned the bass settings on the HU all the way down... The sub was literally turned off... During my car ride, volume at 11/35, heard a pop... Smelled "burning" once again yelled put the word FFFFUUUU at the top of my lungs... Figured something was fucked.  Pulled over, saw no smoke... Got to my destination... Pulled the fuses... All 4 fuses were fried and broke apart...
So now I'm left with another possibly broken amp, and I don't know what to think...
I'm literally scarred to put new fuses in it...  I just don't get it, I don't abuse it... I don't clip it, it's only running at 2 ohms...
Bill, please respond to my emails...
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon)
3x XS power D2700's
Knukonceptz 0awg all around
That sucks bro
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
This only happens when you drive, could there be a short SOMEWHERE?
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
I am 500% positive there is not a single short in the entire install... I was so meticulous and careful with the entire install,.. I even double checked the entire thing after the first one gave me problems.
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
Your lpf is a slope not a hard cut. Meaning that you will play frequencies below the set point but at much less output. Which means, if you set to 150 your still playing down to 80 just not as loud. Find the safe medium for your application and test/tune for what sounds best. You can also "double crossover" using two crossovers (ex. Eq and amp xovers) both set to the same setting
I pretty much got the EQ thing figured out... Now I'm just back to hardware problems that make zero sense...
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
what noob said, and also see if there is a db per octave switch on the eq, it will say something like slope 6db, 12db, 24db put it on 24 that the steepest curve.
It sounds like shitz going wrong only when the system is charging???
Current
Ford F350
Alpine IVA-W505
2x Diamond s600
1x Diamond S400
2x RF T1500-1BD
1x RF T600-4
2x AA Havoc 12"
DC Power 230XP
1/0 throughout
Up Next
95 2dr Tahoe
Head Unit= Alpine IVA-W505
Components= 2 Diamond S400, 2 Diamond S500, 2 Diamond S600
Woofers= 2 10" Diamond Hex, 2 12" Diamond D9
Amps= 3 RF T1000-4
Processor= 2 RF 3sixty.2
Subs= 4 18" AA Mayhem
Amps 4 RF T2500-1 BDCP
7 XS Power D3100
3 DC Power 270+
My alternator charges perfectly normal... I always monitor my digital voltage read out on my dash... Never dips below 12.8 or goes above 14.9...
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
