Kicker Trunk Build **2-10's=150.2dbs**
You should do without solder and see if crimping them gains you that .2 db
why without solder? wouldn't it be a better connection with solder
In the short run You'll have less resistance because another element hasn't been added. In the long run Solder makes it corrosion resistant. Solder it.. Its a daily system.
Already soldered bro i may have enough to re run them. And ill cut the terminals off and use it fir the run to the amp
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
Just finished adding another run to the rear, I did the run straight off the alt. to the rear batteries. Now i have a total of 3 runs of +/-. Out of the 50 feet of cable i just purchased i got about 3 feet left. Gotta try and find some dual inputs now for the amps so i can run r runs to each +/-.
Voltage resting at 14.8-14.9 dropping down to 13.7 on music when a good bass hits.
what did your volts use to drop to? and dunno if i saw or not but do you have a mla ?
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
they use to drop to 13.3. not sure what a mla is but i dont think i have one
holy fuckin shit! Badass system bro!
thanks bro. its alright for what it is. :pardon:
Bump or some votes in SOTM. :clapping:
mla regulates your alt to get the most voltage out of it, look it up bro could help out your volts! make them be in the 15v range!
oh alright but for MECA i cant be above 15v.
  • Who's Online   1 Member, 0 Anonymous, 776 Guests (See full list)
