Guest jbinn Posted July 1, 2010 Report Posted July 1, 2010 I have a Sony xplod 4 channel 800w (75x4 RMS) it has 50-300hz LPF/HPF, my question is SHOULD i have the HPF on if my headunit already has 80hz HPF set? or should I just turn the pass-freq on the amp off? im running 4 6.5 Pioneer 4way 50RMS each. off of this.
finkster Posted July 1, 2010 Report Posted July 1, 2010 Turn it off at the amp, the head unit's xover is much much better. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
kingleo Posted July 1, 2010 Report Posted July 1, 2010 I agree. http://www.stevemeadedesigns.com/board/topic/77708-2002-millenia-system-re-build/page__view__findpost__p__1070977__hl__%2Bmazda+%2Bmillenia__fromsearch__1 http://www.stevemeadedesigns.com/board/topic/110130-2000-acura-integra-gs-4-door/page__view__findpost__p__1536749__hl__%2Bmazda+%2Bmillenia__fromsearch__1
Guest jbinn Posted July 1, 2010 Report Posted July 1, 2010 ok will do then another question is there a diagram to tune my mid/highs? I used the one on here for my subwoofer to tune with DMM I wondered if something similar existed to do 4 channels
finkster Posted July 1, 2010 Report Posted July 1, 2010 its the same as for a subwoofer, but you tube it using 1khz instead of 50hz. I did mine by ear, and have had no problems, other than water damage and a short to ground lol. But as far as overpowering goes Im fine. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
Guest jbinn Posted July 1, 2010 Report Posted July 1, 2010 I can do it by ear but I want everything match up when I have my volume up. I want to do it with a DMM if possible there should be a chart maybe?
finkster Posted July 1, 2010 Report Posted July 1, 2010 What do you mean by match up? Like blend well? I dont see how a dmm would help in that situation because every steup is different. You cant just say "well if I have 1k on my subs, then I'll put 300 on my comps" and think it will blend. Try adjusting it little by little and then play a song and see how well it blends. This is also where a bass knob works wonders DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
