are those all 5ch amps???????? to lazy to look
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
if you were gunna run the kicker id say imo itd be cheaper to just get a 4ch and a sub amp, i personally dont like the idea of a 5ch for the fact of you get more power from 2 separate amps in that situation
need a battery? how much are you trying to push wattage wise? as well as what kind of car. screw a 5 channel
Hey bro, are you willing to consider another amp or are you pretty set on either one of the two? If you are not set on either amp, I would suggest the Hifonics Zeus ZXi 60.4+1k. It is an Awesome amp bro! It puts out 60 x 4@ 4ohm to your mids/highs and you can wire the 5th classD channel down to 1ohm and get 1000w out of the 5th channel. Also, you can save some money because the Zeus amp is $389 on Audiosavings.com and the Kicker zx700.5 is $499 and the 5th channel on the Kicker amp is less than HALF of the power on the Hifonics. However, if you are dead set on getting one of the 2 amps you have listed, go with the Kicker bro. The specs don't even compare. Hope this helps you out bro!
-Baseline
your not gunna need a batt, shit, fuck your tech lol, how much power are you looking to put to the sub? check my sig i had all that running with no batt stock alt and NO DIMMING at all
  • Who's Online   0 Members, 0 Anonymous, 420 Guests (See full list)
