hello i was wondering if anyone could help me i was wondering if its possible to wire three 12 inch alpine type x's to one ohm thank you
not to one ohm, it will load at either 2.67 or .67 ohm load so your best bet is to wire it in series to give you a safe 2.67 ohm load depending on your amp specs, if its a 1 ohm stable you might be able to run at .67 load but you'll have to reset the gain down and keep an eye on the amp, it'll produce excessive heat dissapation.
better hope you get alot of box rise if you do .6ohm lol depends on the amp though.
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
whats the coil configuration?
I know a lil about everything so dont call me Mr. Know it All.
  • Who's Online   1 Member, 0 Anonymous, 2565 Guests (See full list)
