My First Run @ Fiberglass
After I get it blocked and sanded pretty decent and all the curves are smooth, I spray with slick sand by evercoat. Its like a bondo primer. I still seal and primer afterwards. It just takes out several steps of filling pin holes and small stuff. It takes a gun with a big nozzle. And its pretty expensive, but its worth it in the end. Ur box looks nicer than my first try most deff.
ok so I glassed the port in & added some filler around it.
port glassed in, trimmed off some of the excess, & sanded smooth
first ring of filler
second layer to build it up
originally i was thinking i should flare out the port more because i couldn't flatten the edges as much as i wanted to without it cracking. aero ports seem to flatten out on the outer edges more like a trumpet. i'm wondering if the flatness is just so you can screw them to the box. will making it flatter make a difference?
i started sanding my filler flat.
then i was thinking of doing something more round like this
can't decide what i should do. will making it flat like an areo port reduce anymore noise than the round design? any input is welcome.
been pluggin' away at this little by little & progress has been a bit slow lately but it's still comin' along.
more spot treatments to remove the pits.
I went around the ring with some bondo to smooth it out more
i added a flare on the inside of the port as well to reduce port noise. i still have to glass it on
  • 3 weeks later...
Look alright but i would have use another bondo because i think there alots of pin holes and that i don't really like because you really got fill those holes up and sand it down smooth. Otherwise paint can show very uneveness and something the holes..
This is why i recomended spraying slick sand. Time saver for sure.
  • Who's Online   0 Members, 0 Anonymous, 1966 Guests (See full list)
