superdave07 Posted July 9, 2010 Report Posted July 9, 2010 Alright a buddy and i are having a debate maybe you guys can help me. In my civic as of now im running an AP30001d and two 15" Fubars. The subs are dual 4 ohm. I have them running off both channels on the amp at 2ohm per channel. Clamped my amp is doing 1205rms per channel. Heres the debate, He says if I bridge the subs to 1ohm and run them on one channel, ill get more power to my subs since the amp is 1500rms at 1ohm per channel. I disagree because I thought If I bridge them it will divide the power between the two subs? Who is correct here? Thanks guys Xterra * 69 Camaro * Audi S5 36 Ford * 51 Mercury looking for wire sponsor www.flyracing.com
dugee81 Posted July 9, 2010 Report Posted July 9, 2010 well with those audiopipes, the lowest impedance you can go (bridged) is 2 ohms. 2 ohms bridged will produce around the rated amount (3000 wrms). running 1 ohm bridged will probably give you more power, but they arent stable at that level unless you have strong electrical to back it up. if not, pooooof out comes the magic smoke 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
superdave07 Posted July 9, 2010 Author Report Posted July 9, 2010 Im talking about running 1ohm on one channel meaning one side of the amp. they are stable at 1ohm per channel..... Xterra * 69 Camaro * Audi S5 36 Ford * 51 Mercury looking for wire sponsor www.flyracing.com
Robert8252 Posted July 9, 2010 Report Posted July 9, 2010 Help me understand the amp better. Is it mono but has two inputs or is it a 2 channel amp? I think it's actually mono so even though there's two inputs it ties then together anways in parrallel I believe. So I think you get what I'm saying. Bridged between the two or each on their own it is still seeing the sane load. So you amp should actually be seeing a 1ohm load when it puts both 2ohm speaker loads together. Hope I made sense 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
dugee81 Posted July 9, 2010 Report Posted July 9, 2010 Im talking about running 1ohm on one channel meaning one side of the amp. they are stable at 1ohm per channel..... idk if i would use just 1 channel of the two?? plus yeah you would be giving less power to your subwoofers. so yeah you are correct, not your friend. right now you (said you) are giving each sub 1200wrms. putting them both onto one channel will be pointless as it WILL split the 1500 into two and give each subwoofer 750wrms. 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
superdave07 Posted July 9, 2010 Author Report Posted July 9, 2010 idk if i would use just 1 channel of the two?? plus yeah you would be giving less power to your subwoofers. so yeah you are correct, not your friend. right now you (said you) are giving each sub 1200wrms. putting them both onto one channel will be pointless as it WILL split the 1500 into two and give each subwoofer 750wrms. ok thanks thats what i thought. As for the amp being being a mono or 2 channel. its basically two 1500d amps in one case strapped. I believe since they are dual 4 woofers that one per channel would be 2 ohm per channel? Xterra * 69 Camaro * Audi S5 36 Ford * 51 Mercury looking for wire sponsor www.flyracing.com
dugee81 Posted July 9, 2010 Report Posted July 9, 2010 ok thanks thats what i thought. As for the amp being being a mono or 2 channel. its basically two 1500d amps in one case strapped. I believe since they are dual 4 woofers that one per channel would be 2 ohm per channel? that is correct, with your current subwoofers, each channel will see a 2ohm nominal load 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
