Hello there im new in car audio systems , im waiting for my amp to arrive Hifonics Brutus BRZ2400.1D , i will run 1 kicker L7 12" at 4ohms but in a month will buy another kicker L7 12" , how do i make amp settings right for this 1 kicker L7 12" 750rms i dont want to damage my amp or sub please help me. if you can use paint and edit first image by adding dot on each switch so i would know how to set it up.
RMS Power Rating (@ 14.4V):
* 4 ohms: 850 watts x 1 chan.
* 2 ohms: 1700 watts x 1 chan.
* 1 ohm: 2400 watts x 1 chan
Bass EQ on 0, Subsonic at 3hertz below tuning.
Phase at 0, and the level=gain you ned to set it with a Oscope or with a DMM.(search for the tutorial Setting gains with a DMM under the amplifier section)
Lowpass depends on the user, i like it at around 60-65 hz.(some like it higher, just turn it a bit till you think it sounds right)
  • 6 years later...
