no point in using a reducer in my opinion. let the amp use the power wire that it was meant to use. i understand the point of having bigger wire to let more current flow but 4 gauge will be just as sufficient.
15ft of 4 gauge should be plenty, but 20ft couldnt hurt as every vehicle is different. and 10ft of 12 gauge should be fine also.
the 1200d has 120 amps worth of fusing so go for a 150 amp fuse.
If you do go with 4g (nothing wrong with that as said above it's enough you just can't upgrade with it) just remember that some brands of 4g are only rated at 100a.
Edited by UnderLoK
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
