ok so ihave no idea how to wire my set-up i have 3 amps all of which i want to put 0 guage inputs into and i also have a 2nd kinetic battery i ned to install in the trunk to go along with the stock one in the front but i have no idea what kind of fuses or anything i need and how to wire all of this so if any 1 can tell me it would be much apprecitated
Run of 0g wire from front batt positive and one negative to rear battery positive and negative. Then run 0g from rear batt to all amps. Each having there own wire meeting at the batts positive. Ground all amps separately with their own bolt and spot. Fuses....depends on how much current you are actually running but one within a foot of the from battery and before the rear battery. And one on each power wire from rear battery to each amp closest to the battery.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
run 0 gauge from positive and negative from the front battery to the back batteries, fuses go with in 18 inches of the battery.. that's pretty much it dude
i don't use fuses
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
i don't use fuses
uhm... im tryin to figure out how to lionk both of my yellowtops, i thought you just had to run positive from front battery to the positive on the rear battery with a 300 amp fuse? i only have 1 3k amp
1998 GMC Jimmy 4 Dr.
-SINGER 275 Amp Alternator
-150 FT. Of 1/0 OFC (8 runs) 4 pos, 4 neg. Front-back.
-Audioque AQ2200D @ .5 ohm
-2 Audioque HDC3 18's Tuned to 27-29 HZ
-4 Clarion 6.5's
-2 Optima yellowtops
  • Who's Online   0 Members, 0 Anonymous, 2669 Guests (See full list)
