k3n12ock Posted July 16, 2010 Report Posted July 16, 2010 So I am in the process of adding a negative 0/1 run to the back. QUestion, am I okay going straight from the front battery negative to the amp since I currently have no rear battery? That is all, thanks. Quote 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
Guest Posted July 16, 2010 Report Posted July 16, 2010 dont do that wit hthe ground. attach a lug to a piece of 1/0 or w/e that is 4ft long at the MAX and bolt it down the a non painted surface (or paint that was sanded off) to a thick piece of metal (not a seat bolt or something like that) Quote
JZeFF Posted July 16, 2010 Report Posted July 16, 2010 Why is it bad to ground directly to the battery? I have heard some people say that's the beat possible thing to do, and your saying that's not good to do? Why is it bad? It would be the path of absolute least resistance possible in a car... Quote Pioneer x930 bt Rockford t2500 bdcp 18" nightshade v1 DC audio 175.4 RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon) 3x XS power D2700's Knukonceptz 0awg all around
dugee81 Posted July 16, 2010 Report Posted July 16, 2010 Yeah you want the ground from the amp to be as short as possible. It would be helpful to do a - run to the back if you had an additional battery. Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
Guest Posted July 16, 2010 Report Posted July 16, 2010 having a 15 foot long ground will have more resistance than a 3 foot long ground bolted to a piece of thick metal (or frame) Quote
k3n12ock Posted July 16, 2010 Author Report Posted July 16, 2010 No battery but I just started have voltage/ground problems and I'm thinking a run to where my ground is right now, then from there to my amp would defeat the whole purpose of having the run. Now if I had a battery in the rear, it'd be different. But idk. I just don't want to fuck up my amp. Quote 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
JZeFF Posted July 18, 2010 Report Posted July 18, 2010 having a 15 foot long ground will have more resistance than a 3 foot long ground bolted to a piece of thick metal (or frame) Alright, I could see what you mean... But say the battery is under the back seat? In that case would grounding directly to the battery be a bad thing? Quote Pioneer x930 bt Rockford t2500 bdcp 18" nightshade v1 DC audio 175.4 RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon) 3x XS power D2700's Knukonceptz 0awg all around
MrSkippyJ Posted July 18, 2010 Report Posted July 18, 2010 Won't hurt anything but why do through all the effort of running a 1/0 cable when you can just use the frame? Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
finkster Posted July 18, 2010 Report Posted July 18, 2010 Only way to know is to measure the resistance from said ground spot on chassis and see if it has less resistance than your run of 1/0. My money is going on the 1/0. Quote DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
MrSkippyJ Posted July 18, 2010 Report Posted July 18, 2010 If the resistance is good enough for the power wire, why wouldn't it be good enough for the ground wire? Assuming the battery and alt grounds are good then using a run of 1/0 would be just fine. Of course, with multiple amps and such it is just way easier to use the frame as a ground. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
