dcyphure Posted July 24, 2010 Author Report Posted July 24, 2010 Fark me! I'm positive something is wrong here. This is what I got, 8" port. The blue line was 3.5 cubes, ignore it. pink was a Qes of 0.293 white was a Qes of 0.586 this is because I don't know how kicker measured it, it could be separate coils, parallel or series. No offense, but I'm sure you did something wrong. All graphs worked for me. Ok thanks. Dunno why i can't get bassbox pro to work right, it worked before but now it never shows me a graph line, but i dont' know what a lot of stuff means either. Winisd just sucks, thats all there is to it. Can you show me what your graph shows for two 2" inch ports, just so i know. i'll add bigger ports another point in time, i'm broke now.
bassl0va Posted July 25, 2010 Report Posted July 25, 2010 Ok thanks. Dunno why i can't get bassbox pro to work right, it worked before but now it never shows me a graph line, but i dont' know what a lot of stuff means either. Winisd just sucks, thats all there is to it. Can you show me what your graph shows for two 2" inch ports, just so i know. i'll add bigger ports another point in time, i'm broke now. Do you get a graph if you choose a woofer that comes in the woofer library? Then just try the suggest box function? You should be able to get something out of it. But you need both a driver and box to get anything from the graph. I've seen winISD used successfully, but I find it a bitch to use. And bassbox pro is better, hence why it costs money. I would just sell the 2" ports and build a slot port, you will not have fun with the 2 2" ports, it is more like a leaky seal rather than a ported. It shouldn't be higher than the yellow line (8" port) really, but as you can see, it is through the roof. My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
