4 Ascendant SMD 18's, 36kwrms!! - teamSPB Project D*FN U...NEW UPDATES! 9kwrms PER SMD!!
Lookin good, but imo the bumpers just look weird cuz of the way the engine bay is...
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
Last few bits and bobs on the exterior....
Bulb change
Not really a fan of orange indicators...
The lights were cut open, and then the orange filter broken and cut out...coupled with some silver bulbs
This was the result
MUCH better
teamSPB
go to your first post in the thread and click edit< and then click use full editor and you will see it on top
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
Thank you kind sir! All done now :)
And thank you to the other people that mentioned it...I didnt click the full editor...ops!
teamSPB
After the air ride project...it was time to strip the vehicle down for some sound deadening....
For some reason I have lost alot of pics of this stage, so will put up what I have...
Right...what was used for sound deadening.....
ALL the sides was done with 2 layers x 4mm Loudboys deadening + 2 layers x Second Skin Damp Pro + SS Overkill (just wanted to test the Overkill product out)
The floor was done with 1 layer x 4mm Loudboys deadening + 1 layer x 18mm MDF
The roof was done with 2-4 layers x 18mm MDF
Any gaps were filled with fire retardant expanding foam
Vehicle stripped
2 layers of LD's deadening applied
SS Damp Pro applied
Other side was stripped and done to
Both sides done...Note the Turbonetics T61 turbo sat there ;)
Tailgate is also deadened fully...however, its now too heavy to stay up in the air so a pair of molgrips come in EXTREMELY handy LOL!
Next up was to attack the floor...
teamSPB
Layer of 4mm deadening going down...
This stuff was a great size for laying down on a large area...no cutting was needed at all thank the lord! LOL! It really is a bit of a pain to work with...but man does it stiffen up panels!!!
Making MDF panels for the flooring
Then bonded and glued into place
There was then around 100-150kgs of weight added on top of the MDF to help adhere properly to the deadening below...
Once this was cured (I allowed 3 days), I done a test...try to lift up the MDF from the corner with all my force...I did my back in LOL!!!!
At this point, the next step was the Roof....
It is REALLY weak, AND I had the added bonus of TWO sunroofs which is a pain in the ***!!!
First off was to tackle the thin sheets of metal.....Welcome Mr Singh (Am) to help me with this bit...with the roof sanded down, it was time to cut some MDF and bond it to the roof...
This piece was cut to cover the complete roof section (Well from driver seat back)
Where the sunroofs are...LOADS and I mean LOADS of insulation was used to keep pressure applied to the glass...this was placed and glued onto the MDF
This picture shows around half the amount used on the second sunroof
On the outside, the glass has been sealed and bonded shut...seems to work a treat!
teamSPB
The roof section was then raised....and PACKED....when I say packed...I mean around 8-10cans of expandy foam!! The roof is SOLID!...I got up on it and jumped...and took my weight no problem!
The front sunroof was also covered up and everything was FG'd together...
teamSPB
