4 Ascendant SMD 18's, 36kwrms!! - teamSPB Project D*FN U...NEW UPDATES! 9kwrms PER SMD!!
I managed to get some work done over the weekend on the Previa amongst other cars...Everyone is desperately wanting me to get their cars ready for show season....me included!! Hard to turn down customers when they are the ones to essentially are putting food on the table!
I had a few stickers piling up for a little while now, and now that the Previa is back...I can finally get them on...
How it started off
And after
And my best sticker....
More coming later!!
teamSPB
While the Previa was away, I decided to work on the fuse rack...I worked out we need around 18 fuses...meaning in todays prices...around £270 in fuse holders plus fuses!!! That idea was duely scrapped and I decided to work on a fuse rack which could be implemented into the boot area...This would need to house around 15 fuses.
So, I was working blind...the vehicle wasnt with me so I could get exact measurements so knew there might be a bit of trimming work in order to get the holder to fit. It kept my mind busy so I didnt mind so much
Fuse box made up
Marked up
Nuts, bolts and washers at the ready
FG and filled edges to they dont look so 90degree'd
The box was then PVA'd to help make it waterproof and then sprayed with primer
Fuses mocked up
teamSPB
The fuse rack was then sprayed black...
The reason I put so many layers of 'protection' on, was to stop the MDF trying to absorb any glue for the next stage....
Which was time for flocking!! Inside of the rack was then flocked in the same colour as the interior panels of the car...a custom mix of grey....was a mixture of grey, black and white
After a few days....we ended up with this
The finish really has to be felt to be believed....its awesome! a HUGE HUGE thanks to Nikki at Banbury Flocking Services... www.banburyflockingservices.com Or contact Nikki on 07732 902184 Anything you need flocking, please dont hesitate to get in touch with myself or Nikki direct and let her know you got the number through me.
I tested some LED's in the fuse holder
Slowly getting there now!!
teamSPB
So each fuse is guna have 2 leds? :P NICE!!!
Live life to the full... Then TURN THAT BITCH UP!
Vids will soon come ;) Just need to finish a few bits then I can get it running again
On a side note...I did do 154dB @ 31hz with the alts in, and 2 Halfords batteries...fully sealed up in accordance to dB drag rules
teamSPB
Lookin good :) cant wait to see what way you're gona work the beauty panel for that :)
wow, I just went through this whole build in the last hour or so, and it is awesome, I love everything you have done, just wow!!! cant wait to see it finished!!
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
