BJD3 Posted July 22, 2010 Report Posted July 22, 2010 I have a DD M1a. This morning I was bored, so I pulled my 12 out of my HT sub box and tossed it into the box in my car. My gains had yet to be set, so I was planning on using the remote to tell me when I ran into clipping. Not the best way, but I figured it would be good enough. So I turned the gain on the amp all the way down, the remote all the way up, and put on a 0db sine wave I made in Audacity. I start turning the gain, and nothing's happening. Then I realize the master/slave switch is in the wrong position, so I put it in master, and tried again. At this point I'm getting sound, but the clip light still isn't coming on. Then I start hearing distortion, and I know that's not good. I turn the gain back down. I pulled the remote out of the car, and use another telephone wire to connect it to the amp. The power light comes on, but the clip light does not. So I figured I'd set it by ear, turn the gain down quite a bit from the audible distortion point, and hope for the best. So I set the knob back up in the car, and...nothing. The knob itself doesn't work. I go back to the trunk and connect it via the other cable, and the knob still doesn't work. tl;dr the knob doesn't work the power light lights up the clip light doesn't light up I tried switching cables. Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
BJD3 Posted July 24, 2010 Author Report Posted July 24, 2010 bibbity-bobbity-bump. I'm going to be getting access to an oscope (or at the very least a decent DMM) so my gains should be set properly in the coming days/weeks. I don't drive much, so even if it takes a week or two, that will only be an hour or two of driving time. Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
