superchargedamd Posted July 23, 2010 Report Share Posted July 23, 2010 just wondering if two speakers that are the same (ie watts size brand stroke) but the ohms are diffrent can be used on the same amp in a series or parallel config.thanks Jensen head unit (junk to start) cadence 5.25 dash re tweets Candence ultra drive amp(mids+highs) rockford fosgate 75hd RESX18D2 X4 subs wired to 1.3 final REBUILDING AS WE SPEAK Link to comment Share on other sites More sharing options...
Guest Posted July 23, 2010 Report Share Posted July 23, 2010 dont do it. the one thats 2 ohms for example will get more power than the 4 ohms one. Link to comment Share on other sites More sharing options...
cqtama Posted July 23, 2010 Report Share Posted July 23, 2010 ok basically, the lower the ohm load the more power the amp will put out. so for example a 15" sub on a 1000 watt amp will see more power and be louder wired to 1 ohm than if it were wired to 4 ohms (assuming said amp is 1 ohm stable). however, the lower the ohm load the stronger your cars electrical setup will need to be since it takes power to make power and without enough current going to the amp you can damage equipment. EDIT: don't use speakers with different ohm loads they need to be the same or you will fsu R.I.P '01 blazer you treated my ears well until your transmission blew up. New Project [top secret] 149.0 db on music driver window open; so close I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean.... I swear... sometimes I wish I was retarded so I could just agree with everyone x. Link to comment Share on other sites More sharing options...
justinadams Posted July 23, 2010 Report Share Posted July 23, 2010 from what i understand. it is highly recommend to not run and speaker/subs. in series for the exact reason kranny said. 2 12" memphis mojo mojo12d4 hifonics brutus bxi 2610D 1/0 power wire 4 gauge speaker wire ddm tuning 8000k 35w hids C&D technologies battery (100 ah) custom box tuned to around 45hz(designed buy fritosaregood) 2010 kia forte koup Link to comment Share on other sites More sharing options...
cqtama Posted July 23, 2010 Report Share Posted July 23, 2010 from what i understand. it is highly recommend to not run and speaker/subs. in series for the exact reason kranny said. its not bad to run them in series, it depends on the situation. the problem is using speakers with different ohm loads. each speaker will be seeing different amounts of power. R.I.P '01 blazer you treated my ears well until your transmission blew up. New Project [top secret] 149.0 db on music driver window open; so close I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean.... I swear... sometimes I wish I was retarded so I could just agree with everyone x. Link to comment Share on other sites More sharing options...
