1.5 cubic feet and be tuned at 31hz
well i want the low lows and want to use a slot port. i and i have the room for a box that 32" wide 26" to 27" deep and 26" high and kind wanna do a port like steve meades
Team DBs (Driven By sound)
well i understand you have alot of space, you can make the box as big as you want it the bigger the box the bigger port you're gonna want to make.. but i wouldn't go too big thats overkill and at 1200 rms a piece for each sub.. you need good electrical and lots of power :)
96 jeep grand cherokee and running roughly 800 to 900 watts to the subs for now. the amp is most effective at 14.6 volts and the damn ecu contraled voltage regulator limits me to 13.4. but at 14.5 at one ohm the amp will do 2400 rms
well i have a 136 amp alt and 2 gel cells in the back all 1/0 cables big 3 but like i said limited to 13.6 volts til i can bypass the ecu voltage regulator
ahh gotcha, ok then you need one of those, what they fuckin call it.. missing link regulator, it hooks up to your factory regular to allow you to bypass it i think thats what it does.. if i'm not mistaken but you should crank the bish up.. you'd be suprised
  • Who's Online   0 Members, 0 Anonymous, 893 Guests (See full list)
