Okay, i have a 15'' L7 in a 5.8 cubic foot box. I dont want to mount the subwoofer with screws like you would normaly do. so i figured i would go with bolts since its a little more heavy-duty. but my question is how would i go about sealing the bolts on the inside of the box? or would the pressure of the nut tighting on the outside of the box keep the head of the bolt tight enough on the wood for a seal? or should i put a little sealant on the bolt?
06 Honda Civic Si
Sub: 15" Kicker L7
Sub Amplifier: Phoenix Gold RSd 1200.1
Head Unit: Kenwood KDC-HD545U
Speakers: undecided
Speaker amp: undecided
Still alot more to come!!!
locking nuts or something like that
they have lil teeth and all u do id hammer them in the wood
Edited by splzx3
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
They are called T-nuts, you can purchase them at your local hardware store. Simply drill the wood out to the size needed then insert them from the backside. You will have to either beat them in with a hammer or pull them into the wood by using a bolt and washer.
1999 Chevy S102 Sundown Zv3-10's1 Sundown saz-4500d2 sets of Sundown CS6.5 Comps. (Doors)
2 10" Sundown NeoPro 10's (Doors)1/0 KnuKonceptz - Power x2- Ground- Big 3
300 Amp External Regulated Excessive Amperage Alt
147.8 Sealed Mic on Windshiled148 30sec. Average Drivers Door open Mic on Windshield
Check Out my YouTube Channel --->>> http://www.youtube.com/user/dmntyo2007?feature=guidehttp://www.stevemead...ld-competition/
thanks bro i had a brain fart lol
okay i got that part, thanks. but are those going to get a good seal. or am i going to get air leaks of any sort? do i need to put any sealant on the t nuts once their in?
Or would just drilling the holes for the bolts so the bolts are a really tight fit do the job?
Edited by fuggnore
06 Honda Civic Si
Sub: 15" Kicker L7
Speakers: undecided
make the holes 1 size smaller and just hammer them in and call it good
Your sub gasket Should seal it up
t-nuts will help out alot bro
y 1/2 ur system then pay more later
okay thanks everybody for the input and so quickly. i got another question too. haha, so im mounting the sub box with a 4x4 that is mounted between two pillars on either side of the trunk. i was plannning on bolting the box to that from the back side of the box. i was planning on three bolts. two on either side and one on the middle. would you recomend t nuts again just a bigger size?
this box is being mounted in the rear of my car rather then the trunk due to small trunk size.
i have removed the rear seat, and have a peice of 1" MDF for a platform. i have pictures if that would help at all?
06 Honda Civic Si
Sub: 15" Kicker L7
Speakers: undecided
