I got an underbody kit installed on my car a little under a year ago. They wired it up so it will only turn on when the car is on. I never really cared about this until recently. It is not wired to my battery, it's hooked up to something else but I have NO clue what it is. If the battery/engine is on, than the lights will turn on, but they are off as soon as the battery is off. Does anybody know what it could be wired to? The wire goes up my dash to SOMEWHERE but not sure where.
Ignition maybe?
I was actually thinkin' that too. Shouldn't be a hard/time consuming fix. Which would also explain why the surrounding trim piece of the ignition/steering wheel was screwed in loosely since then.. lol
Edited by Tek
it's not hooked to the fuse box???
no. is it supposed to be? I thought people use the battery?
*EDIT* if you mean the under hood fuse box, that is what I was planning on hooking it up to afterwards.
Edited by Tek
its most likely wired into your switched wire under your steering column
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
i just did some neon lights today!
the way i wire it was to the battery and to a switch so that you HAD to turn them on weather the car is on or off, im sure theres different ways of wiring them up tho....
if you wire it into the fuse box they sell this "small fuse holder with a wire" thing at autozone that would work great! its cheap too
it already came fused, but thanks a lot!
  • Who's Online   1 Member, 0 Anonymous, 2015 Guests (See full list)
