pa system help!!
Looks like your Yamaha mixer makes 200 watts RMS per channel at 4 ohms. You have two choices, add a powered sub by connecting it to the mixers subwoofer line output or use a passive sub with a passive crossover network. If you elect to go passive, purchase a dual voice coil woofer (dual 4 ohms would be ideal), install it in the box of your choice, and connect one of each of the mixer's output channels to each coil of the woofer. To filter frequencies above 100 hz from the woofer, connect a 6.4 mH coil in series with each voice coil (on the positive).
I will caution you that your mixer is rated at a minimum of 4 ohms per channel. If you go passive and you are also using 4 ohm DJ speakers connected to each channel, you will have to wire a 200 microfarad capacitor in series with each (on the positive). This will filter frequencies below 200 Hz from them. This will create a slight gap between the 100 Hz low pass point of the woofer and the 200 Hz high pass point of the DJ speakers. Connected in this fashion, freqency response should be fairly smooth between the woofer and DJ speakers and the amplifier in your mixer should have no problem coping with the load. This kind of passive crossover network is called a first order. First order networks have a 6 dB / octave roll-off. If you have 8 ohm DJ speakers, use 100Hz capacitors instead.
If you would like to learn more about passive crossover networks, I recommend that you purchase The Loudspeaker Design Cookbook by Vance Dickason.
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
Just research everything snafu is trying to tell you, not that confusing lol
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
