which amps are better for two btl's
Flint_810
whats going on ppl? i currenty have 1 15" BTL looking to upgrade to two soon. i was wondering which amps would be better to hook up to them. one crescendo3k, put one audioque2200 on each sub? or just go with the audioque3500 for both subs? i'll appreciate all you guys comments thanks!!!
[color="#2E8B57"]size="4"]1998 buick century
stock elcetrical for now
pioneer 3100 avh dvd HU
(12)power acoustik tweeters
(1) PA BAMF 5500
(1) FI 15" BTL HEAVY SUB!!!
(1) kenwood 720 4cahnnel amp on da way
(1) 20ft run of rockford fosgate 1/0awg
(2) 1/0awg to 4awg reducers
(2) memphis front speakers
(2) kenwwods 69ie 6x9's
(1) deep cycle batt on the way
(1) 5cft box tuned to 32hz after displacments
ALOT MORE UPGRADES TO COME!!!!![/size][/color]
It depends a lot on box size, port area/tuning IIRC.
I would think a 2200 per would be plenty, then again I've never even seen a BTL in person so take my advice with a grain of salt.
Too many projects, too little time...
I would go with the 2 2200's, that will yeild the most power I believe.
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
It really matters what size box and port. it would help if u let us know what you r trying to go for too. SPL? what r u doing in the build?
i have one btl in a buick century that's in a 5cft box. my plan was to add another btl and get a custom 7.5-8cft box made for the two just want to get my amps batteries ect for my build but kinda confused on the amp tip
(1) PA BAMF 5500
its a 15" btl btw
(1) PA BAMF 5500
i run an 18 in just under 6 cubes... on 3k daily and it takes it no problem i can bearly move the sub id say a cresendo 3k per sub myself...
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
How many ohms is the sub?
If it's for example a 2ohm sub, then you would want 2 amps running at 1 ohm each or 2 ohm strapped (4 2ohm coils can produce .5ohm or 2ohm). If the sub is 1 ohm then you would want one amp (4 1ohm coils can produce 1ohm).
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
  • Who's Online   0 Members, 0 Anonymous, 959 Guests (See full list)
