SubSonic Posted August 5, 2010 Report Posted August 5, 2010 Ok, so just for example, on a Sundown Amp, the PHASE tuning switch, iv heard this either, A, "makes the sounds from the subs reach you when the door speakers do" , or B, "IS FOR ONLY, when u invert the subs in the box", Or C, Switches Polarity From the amp to the woofers, I just want a legit answer for what it exactly does, and is it the same for every amp more or less, please let me know, thanks alot for your time.. Re Audio Diamond Audio Alpine Audio Rocksford Fosgate DB Link
speedball1978 Posted August 5, 2010 Report Posted August 5, 2010 most amps do not have this switch, most amps have 0 and 180, what you have is a 3 phase selective switch and should be used accordingly to what your manual says dependent on your setup...
speedball1978 Posted August 5, 2010 Report Posted August 5, 2010 but if the amp has only a 0 and 180, then its dependent on the inverting of the subs most inverted subs require a 180 which turns the polarity around, but if lets say you have one sub inverted, and the other is standard, then you leave it at 0 and flip the wires on the inverted subs backwards.. so that it will move the cone in the same direction
SubSonic Posted August 5, 2010 Author Report Posted August 5, 2010 SO it is for inverting subs? thats it? Re Audio Diamond Audio Alpine Audio Rocksford Fosgate DB Link
Guest Posted August 5, 2010 Report Posted August 5, 2010 alls you have to do for inverted woofers is just switch the + and - for polarity, simple as that, but i heard it doesnt even matter... dont mess with it if you dont know what it does, also Google http://forum.lowyat.net/topic/818315
