Integra_boomer Posted August 9, 2010 Report Posted August 9, 2010 I have a zx1500.1 that does 1500rms @ 2 ohms, thing is i have a D2 ohm fi BL and 4 ohms will not be enough at comps. So would it be safe to burp it at 1 ohm for competitions? 1995 Integra GSR (DB8) Pioneer 3200-DVD 6.5 rockford fosgate 2-way fronts 6.5 rockford fosgate 3-way rear saz-3000D (2) 12" SA-12s
EricR Posted August 9, 2010 Report Posted August 9, 2010 Did you really need 2 different threads? i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
Freshman6969 Posted August 9, 2010 Report Posted August 9, 2010 Did you really need 2 different threads? this Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
