Triangle Port Question
Hi Guys,
Having a bit of trouble here.
My box size;
38" Wide
35" High
25" Depth 1
30" Depth 2
I was going to tune it to 33hz unless someone thinks I should tune otherwise to something more / less.
Running 3 kicker L7's but currently have square ports currently but was going to convert them into Triangle thought it would look a lot better. I'm going for pure SPL not SQL in the least. Can someone help me work out the sizes? I've tried doing the math it's fairly simple but for some reason I dont think I'm doing it right.
Here is the current box, this was a picture taken last weekend. Its not even close to done.
Thanks in advanced, hope someone can help.
Edited by Cynner
I'm not an out of control driver, I'm completely in control.. only sideways..
-Nissan R32GTR running 213KW RB20DET on 14lbs of boost.
-Holden Commodore VY SS UTE running stock.
-Holden Rodeo mini truck project, soon to be running SR20 on 13lbs of boost.
-Landcruiser UTE running 1UZFE v8 11" Lift on 35" MT Classic II's wrapped in Cooper STTs.
^^ and the list goes on..
I think the most simple way to do this would be to do the port calculations with a sqare port. Once you have the proper dimensions of the square port, you can use that area to determine the area of a triangle you need, and you wont need to calc. the length because your going to be using the same port area as befor. Just a differnt shape.I recomend using this calculator, verry nice tool.
Edited by blade7022
<>< Collosians 2:13-14, Philippians 4:13, 1 John 4:7-10
2 - JBL W15Gti
2 - JBL BP1200.1
Knu 1/0 Wiring
Kenwood KIV-BT901
Kenwood/Garmin Nav.
Just FYI the equasion for finding the side of a equalateral triangle based on the area is a re-work of K=a2(√3/4) Where K=area and a=side of triangle. The re-worked equasion is
((4/√3)K)=a. I say use and equalateral triangle because all you have to do is find the width of the trianle and cut 3 boards to to the width(+7/8" to compensate for the miters assuming 3/4"MDF/Ply) and length and put opposing 60 degree cuts on all 3 and put it together. Ex. Say you find your port lenth to be 18" and width from equasion to be 7" on the dot. You would cut 3 boards(3/4" assumed) to dims of 7 7/8" x 18".
Edited by blade7022
2 - JBL W15Gti
2 - JBL BP1200.1
Knu 1/0 Wiring
Kenwood KIV-BT901
Kenwood/Garmin Nav.
That's actually a REALLY good idea. Hmmm...
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
two triangle ports, one in each top corner? Would be badass. Flare the end in the box so they're more efficient.
Hammerdown... 1%
lol ok let me try to explain one more time lol
since you have 2 squares... to convert this to a triangle, the port length can stay the same or be longer to maintain the frequency, but the length of 2 sides will need to be stretched out...so if your square sides were 8 by 8 then the triangle would be somewhere 11 or 12 inches on 2 sides and then whatever the lenth of the 3rd side ends up will be automatic
good idea with the diamond ports..
  • Who's Online   0 Members, 0 Anonymous, 1194 Guests (See full list)
