So I set my gains with an o-scope. I play a 50Hz @ 0dB signal, my "bass knob" is all the way up and I have my vol where I like it.
So I set the amps just below clipping....at 50Hz. Out of curiosity I wanted to see what the o-scope showed as I go down in freq. What I got was that at just about every freq I tried, all the way down to 20Hz....I was getting clipping. Whats the deal?
Is there something I am not doing right?
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
because you need to set the volume at 3/4 tilt, then turn the bass boost down all the way and set the gain up til you see clippin, back down just a hair then reset your bass boost up just a hair if you like, then play all the different tones and see what you get
Why would I set my gain at 3/4? I set my gain just under clipping on my HU. I was always under the impression that you should set your amp gains with the bass knob all the way up
d(-__-)b
Bass boost on my amp?
Here what I did.
Turn "Bass Knob" all the way up
Set HU to just under clipping
Set amp gain to just under clipping
Set Bass Boost on the amp to just under clipping. (dont get much out of this one but just a hair of a turn.
Edited by PUNKYOU007
d(-__-)b
your going to have a box rise change at every frequency. as it looks most likely lower rise at the frequencies you were trying
Johns.jpgSuburban Coming Soon
  • Who's Online   0 Members, 0 Anonymous, 578 Guests (See full list)
