TLEJ Posted August 12, 2010 Report Posted August 12, 2010 So in one car, I've got 2 10" mtxs.. and 1 battery up under the hood. I have a little battery charger where you just clamp on the red and black pinchers, and it charges the battery at 50amps, 20amps, and 10 amps. I have 8 gauge cables coming off the positive of the battery with fuses, and it hasn't blown them.. I use to play music while it was charging. Is that safe? For some reason I think it's HORRIBLE treatment to the amp or something
t-money Posted August 12, 2010 Report Posted August 12, 2010 i wouldnt do that. i turn off all audio if i need to charge 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056
JBERK Posted August 12, 2010 Report Posted August 12, 2010 I know at shows, my buddy's Dad would use a battery charger and have all his stuff going at the same time... Worked great for years, I wouldn't think it'd be a problem, the amps are getting DC power from the battery and the battery charger is feeding the battery DC power as well.. I wouldn't connect the clamps to the side of the post that the cables are coming off of but if it works I'd say you're protected because of the fuses you mentioned.
