Yeah, wired parallel two 4ohm subs give you a 2ohm load....since most monomps nowadays have dual outputs it's pretty straight forward
2003 Dodge Ram 1500 - Deep Orange
Build log - Blowthrought with 4 18's http://www.stevemeadedesigns.com/board/topic/122600-4-18s-in-a-dodge-ram-team-sundown-russia/
Sundown Audio SAX125.2 - Sundown PA 10"
Shok-wiring & RCA's
XS Power D6500
Mechman 320A
Sundown Audio Russia
http://sundownaudio....dex.php?/index
http://www.drive2.ru...ram/ram/skillz/ - more about my truck
http://www.youtube.com/user/Gskillz81
Is it possible to wire TWO 4ohm subwoofers, down to a 2ohm load on a mono block?
2 DVC 4ohm? or SVC? if SVC, then yes. DVC, no.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
Hah well the amp is stable at 1ohm, just 400 watts to many. 2ohms was a perfect match.
just set the gains accordingly, you dont HAVE to run it to the max.
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
I know how to set them not to clip with a DMM.. but how do I do the wattage? Just keep the voltage down to what it matches to?
well with the two speakers combined, what is the total wattage (RMS)?
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
