TLEJ Posted August 18, 2010 Report Share Posted August 18, 2010 Is it possible to wire TWO 4ohm subwoofers, down to a 2ohm load on a mono block? Quote Link to comment Share on other sites More sharing options...
G_skillz81 Posted August 18, 2010 Report Share Posted August 18, 2010 Yeah, wired parallel two 4ohm subs give you a 2ohm load....since most monomps nowadays have dual outputs it's pretty straight forward Quote 2003 Dodge Ram 1500 - Deep Orange Build log - Blowthrought with 4 18's http://www.stevemeadedesigns.com/board/topic/122600-4-18s-in-a-dodge-ram-team-sundown-russia/ Sundown Audio SAX125.2 - Sundown PA 10" Shok-wiring & RCA's XS Power D6500 Mechman 320A Sundown Audio Russia http://sundownaudio....dex.php?/index http://www.drive2.ru...ram/ram/skillz/ - more about my truck http://www.youtube.com/user/Gskillz81 Link to comment Share on other sites More sharing options...
dugee81 Posted August 18, 2010 Report Share Posted August 18, 2010 Is it possible to wire TWO 4ohm subwoofers, down to a 2ohm load on a mono block? 2 DVC 4ohm? or SVC? if SVC, then yes. DVC, no. Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm Link to comment Share on other sites More sharing options...
TLEJ Posted August 18, 2010 Author Report Share Posted August 18, 2010 Whoops, forgot to mention DVC. Yeaa well that sucks Quote Link to comment Share on other sites More sharing options...
juanharu4913 Posted August 18, 2010 Report Share Posted August 18, 2010 (edited) As said above, 2 single coils yes, 2 dvcs no but if u have dvc u could get a amp that runs at 1ohm and PARTAY!!!!! Edited August 18, 2010 by juanharu4913 Quote Link to comment Share on other sites More sharing options...
TLEJ Posted August 18, 2010 Author Report Share Posted August 18, 2010 Hah well the amp is stable at 1ohm, just 400 watts to many. 2ohms was a perfect match. Quote Link to comment Share on other sites More sharing options...
dugee81 Posted August 18, 2010 Report Share Posted August 18, 2010 Hah well the amp is stable at 1ohm, just 400 watts to many. 2ohms was a perfect match. just set the gains accordingly, you dont HAVE to run it to the max. Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm Link to comment Share on other sites More sharing options...
TLEJ Posted August 18, 2010 Author Report Share Posted August 18, 2010 I know how to set them not to clip with a DMM.. but how do I do the wattage? Just keep the voltage down to what it matches to? Quote Link to comment Share on other sites More sharing options...
juanharu4913 Posted August 18, 2010 Report Share Posted August 18, 2010 What kinda subs did u buy that only had 1 voice coil O_O Quote Link to comment Share on other sites More sharing options...
dugee81 Posted August 18, 2010 Report Share Posted August 18, 2010 I know how to set them not to clip with a DMM.. but how do I do the wattage? Just keep the voltage down to what it matches to? well with the two speakers combined, what is the total wattage (RMS)? Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm Link to comment Share on other sites More sharing options...
