Why do you want to know?but anyway stiffer linear roll spiders are normaly used more for spl to keep things under control under high power. The softer ones with the progressive rolls are normaly used for high excursion drivers or lower powered soud quality oriented drivers.
what materials are the linear and progressive made out of?
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
Hammerdown... 1%
