Autruche Posted September 5, 2010 Author Report Posted September 5, 2010 Hooking up the 4 channel today, putting in new speaker wires then we're done until the new head unit comes in later this week. then it just needs new speakers, The tablet pc, the second alternator and the finishing touches on the box. Nice looking port hommie!!!! Thanks dude. Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
bass_addict07 Posted September 6, 2010 Report Posted September 6, 2010 Hooking up the 4 channel today, putting in new speaker wires then we're done until the new head unit comes in later this week. then it just needs new speakers, The tablet pc, the second alternator and the finishing touches on the box. Thanks dude. hey im trying to run speaker wire through my 97 explorer can you take pics of you running the wire through all the grommets? 97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
Autruche Posted September 6, 2010 Author Report Posted September 6, 2010 hey im trying to run speaker wire through my 97 explorer can you take pics of you running the wire through all the grommets? The guys explorer isn't here so I can't take pics right now. You are probably having trouble with the doors, right? those are a bitch. the first paragraph is if you have power windows, it may be the same on the standard window model to, I just don't know. On the driver one there is a can-like thing on the hinge area, the top has a 10mm bolt, loosen that, it takes forever, but the big plug will pop out of the bottom, and you will see a hole in the bottom corner of the piece that is mounted on the door, you can squeeze wire through that, then just poke a small hole in the rubber tube for the wire loom, close to the plug you just removed. Pop the rubber tube off of the truck with a screwdriver. get a metal clothes hanger or something similar, and feed it through the hole you just put in the tube, fold one end over and tie the wire to it and you can pull it through. The rest of the doors just have rubber tubs with no connectors, so they are easy. On the inside of the truck you need to take off the floor trim by the doors, then the side/floor trim that is right under the dash in order to get to where the wire will come through. I f you pop off the floor trim by the doors you will see a wire loom ran through a tube or sorts that you can pop open to run the speaker wiring in it, it is actually big enough that you can run 0 gauge down it, talk about convinient. I hope that helps. otherwise I'll get you some pics later if you still need them. Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
Autruche Posted September 6, 2010 Author Report Posted September 6, 2010 Well, yesterday was a day to bust ass on the explorer, and we got the treble done, and reran the RCAs, put the back seats back in, and got some videos done. We got up at 10 and worked on it until 9, here are some pics, I'll put videos up after I get them up on youtube. First thing we started doing was installing speakers. 6x9s didn't fit in the back, not one to take no for an answer, this is what I did. Fuck this bracket, they're a bitch to take off. without it then I cut the shape out of MDF and bottom mounted the speakers to the wood frame Then I screwed the frame to the plastic and the screws are hidden by the grill. Here's how I did the fronts. First off particle board sucks for this, bit this is what I did. Speakers going in Tracing the speakers Marking the holes to drill Cut out Drilled through the wood and door and mounted Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
Autruche Posted September 6, 2010 Author Report Posted September 6, 2010 Running the RCAs and speaker wire Out crappy head unit that I just had laying around, it works for now Where we mounted the amp. We took out the ash tray to run the RCAs through it for the four channel. Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
Autruche Posted September 6, 2010 Author Report Posted September 6, 2010 All done, for now. GINYU FORCE! Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
bass_addict07 Posted September 6, 2010 Report Posted September 6, 2010 The guys explorer isn't here so I can't take pics right now. You are probably having trouble with the doors, right? those are a bitch. the first paragraph is if you have power windows, it may be the same on the standard window model to, I just don't know. On the driver one there is a can-like thing on the hinge area, the top has a 10mm bolt, loosen that, it takes forever, but the big plug will pop out of the bottom, and you will see a hole in the bottom corner of the piece that is mounted on the door, you can squeeze wire through that, then just poke a small hole in the rubber tube for the wire loom, close to the plug you just removed. Pop the rubber tube off of the truck with a screwdriver. get a metal clothes hanger or something similar, and feed it through the hole you just put in the tube, fold one end over and tie the wire to it and you can pull it through. The rest of the doors just have rubber tubs with no connectors, so they are easy. On the inside of the truck you need to take off the floor trim by the doors, then the side/floor trim that is right under the dash in order to get to where the wire will come through. I f you pop off the floor trim by the doors you will see a wire loom ran through a tube or sorts that you can pop open to run the speaker wiring in it, it is actually big enough that you can run 0 gauge down it, talk about convinient. I hope that helps. otherwise I'll get you some pics later if you still need them. yah i was loosening that bolt forever and just gave up lol but thaanks so much for the help, i was having hell with that driver side door ill let you know if i need some pics, thank you so much 97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
Autruche Posted September 6, 2010 Author Report Posted September 6, 2010 yah i was loosening that bolt forever and just gave up lol but thaanks so much for the help, i was having hell with that driver side door ill let you know if i need some pics, thank you so much Yeah, that bolt takes forever to get it loose, but it's worth it when you see how easy it actually is after that. Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
Dltnjest Posted September 6, 2010 Report Posted September 6, 2010 I'm pretty sure this build inspired me to go out and clean up my wires lol
bass_addict07 Posted September 6, 2010 Report Posted September 6, 2010 Yeah, that bolt takes forever to get it loose, but it's worth it when you see how easy it actually is after that. yep i just popped the bottom off and looks alot easier from here 97 exploder xlt2 18" obsidian audio daul 2 v2s1 sundown audio saz1500d at .5 ohm2 sets of alpine type r components1 MB quart onyx 125.4alpine cda-98871 mike singer 250 amp altxs d3400 in the backall kicker wiringBIG 3singer resonance killer sound deadner throughout
