fritosaregood Posted August 23, 2010 Report Posted August 23, 2010 ahh the kerf for box is only kerfed at the exit.. problem?? The air goes both ways, so you really need it flared on both sides to make much of a difference fritosaregood honostly what do you think about the kerf on my box? should move some air? i just looked at the pic, it doesnt look like the kerf it tangent to the port, but more like just 2 angled pieces, i would have also made it smaller seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
chapo123 Posted August 23, 2010 Author Report Posted August 23, 2010 The air goes both ways, so you really need it flared on both sides to make much of a difference i just looked at the pic, it doesnt look like the kerf it tangent to the port, but more like just 2 angled pieces, i would have also made it smaller why make it smaller? Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
fritosaregood Posted August 23, 2010 Report Posted August 23, 2010 it looks like the radius is more than twice the port width, i just never go bigger than the port width seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
chapo123 Posted August 23, 2010 Author Report Posted August 23, 2010 it looks like the radius is more than twice the port width, i just never go bigger than the port width i just thought doing that would help move more air lol... do you think it might cause a problem..? Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
chapo123 Posted August 23, 2010 Author Report Posted August 23, 2010 bump lol will having my kerf to big be a problem?? Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
fritosaregood Posted August 23, 2010 Report Posted August 23, 2010 i dont think it will cause a problem, just not necessary seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
chapo123 Posted August 23, 2010 Author Report Posted August 23, 2010 ah alight thanks man i appreciate it Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
EricR Posted August 23, 2010 Report Posted August 23, 2010 Lol I think you worry too much, just wait till you get it up and playing then you will know if it sounds good. i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
bigmescan Posted August 23, 2010 Report Posted August 23, 2010 pretty much. but you need to flare both the entrance and exit of the port, and also add one radius of your kerf to the port length. so a 14 inch long regular port would now have to be a 17" long port if you put a 3" radius kerf on each end basically if i where to think about what you said basically make it look like a candy cane. because ive wanted to try and do this but wasnt sure which direction to go as well. It depends on what you glass. when i do it i just flare the kerf since it is too weak without it due to all the wood cut out SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
bigmescan Posted August 23, 2010 Report Posted August 23, 2010 basically if i where to look at it i would make it look like a candycane. ive wanted to try and do this but wasnt sure what directionto go in. SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
