i agree.
you cant put 2 different amps together for a number of reasons. power output, crossovers, even the way the internal components react to everything. you just dont do it. and while we are on this topic, dont mix different subs either. to run 3 speakers you would need one amp, or 2 amps that you can strap. not every amp can be strapped so you have to look 1st. now if you run 4 subs (or 2) you could easily run 2 of any amp you want.
x2
Great Information :)
I would just go with 4 Comps, cuz Sonic has a KILLER DEAL on Kicker Comps right now :P
BUT if you dont have the room, then just upgrade to a differant amp
2006 Saab 9-3 2.0T
Posted (edited)
i say 3 comps because i already have 1 and am going to get 2 more from sonics. ill probably end up buying an amp that will do 500 rms and call it good, how would i run 3 subs to the 1 amp
Edited by dman1049
If you are intent on using 3 subs, get single 4ohm coils, run them all in parallel for a common 1.33ohm load, and use a single, 1ohm stable mono amp to power all 3.
Using the 2 amps you have now just wont work right.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela.
