Chamois Posted August 28, 2010 Report Share Posted August 28, 2010 i agree. you cant put 2 different amps together for a number of reasons. power output, crossovers, even the way the internal components react to everything. you just dont do it. and while we are on this topic, dont mix different subs either. to run 3 speakers you would need one amp, or 2 amps that you can strap. not every amp can be strapped so you have to look 1st. now if you run 4 subs (or 2) you could easily run 2 of any amp you want. x2 Great Information I would just go with 4 Comps, cuz Sonic has a KILLER DEAL on Kicker Comps right now BUT if you dont have the room, then just upgrade to a differant amp Quote 2006 Saab 9-3 2.0T Link to comment Share on other sites More sharing options...
dman1049 Posted August 30, 2010 Author Report Share Posted August 30, 2010 (edited) i say 3 comps because i already have 1 and am going to get 2 more from sonics. ill probably end up buying an amp that will do 500 rms and call it good, how would i run 3 subs to the 1 amp Edited August 30, 2010 by dman1049 Quote Link to comment Share on other sites More sharing options...
HHR Ed Posted August 30, 2010 Report Share Posted August 30, 2010 If you are intent on using 3 subs, get single 4ohm coils, run them all in parallel for a common 1.33ohm load, and use a single, 1ohm stable mono amp to power all 3. Using the 2 amps you have now just wont work right. Quote Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion Link to comment Share on other sites More sharing options...
dman1049 Posted August 30, 2010 Author Report Share Posted August 30, 2010 whats a good amp that will do 500 rms at 1 ohm? id like to do this as cheap as possible as im on a TIGHT budget. Quote Link to comment Share on other sites More sharing options...
pheint_1 Posted August 30, 2010 Report Share Posted August 30, 2010 http://cgi.ebay.com/ebaymotors/HIFONICS-BXi608-BRUTUS-MONOBLOCK-AMPLIFIER-AMP-BXi-608-_W0QQcmdZViewItemQQhashZitem43a0d4c916QQitemZ290461108502QQptZCarQ5fAudioQ5fVideo .... Quote Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela. Link to comment Share on other sites More sharing options...
