XS Power
  • 5 weeks later...
nathan when we talked last you were saying you think i mite have a bad controller. well today i removed 2 of my 3 alternators and left the vcm hooked up to the 1 and it adjusts now. what could be the problem when hooked up to 3? i cant try it with 2 cause of pulleys and belt limitations. any ideas?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I'm not sure what would cause that unless one of the regulators was different than the others, or if one of them failed???
Why type of alt harness do they have? 4 pin oval? Are the alts self excite or do you have power running to them?
the 4 pin oval and they just have 1 wire going to sense wire they are irragis just like on steve use to run. dom said they have to have 12v to the post to turn on. anyways heres my dilema now i can adjust it most of the time but it changes voltage on me why doesnt it hold the voltage i set it at./ plus sometimes it wont let me increase the voltage say from 14.8 to 15.1 or2 why?
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
It changes voltage how? When you have a load on it? Does the voltage drop or increase? Is it the voltage on all the alts or just one or two? What is the voltage output on the alternators set at?
15.1 and 15.2 may be past the alternators capability to sustain that high of a voltage output. Tops for the 12V batteries should be 14.9V.
just one alternator it will go up and down on me. i leave it in adjust mode with the light blinking cause when i lock the setting in it stilldoes it and not when i have a load on it pretty much at different speeds never above 2 k or so rpm. and i dnt know what stock regulator is at. with vcm off the highest reading i got was 14.5
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
I have same issue, when I hook up my VCM to my quad setup I can't lower the voltage below like 15.9 volts if I have all four alts hooked up, If I hook up three I can't drop it below 15.0, but if I just hook up two or one alt to the vcm and other just connected to the stock harness, I have all the control in the world.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
So, above 2k RPM will it let you adjust up and down the voltage range when you have them all hooked up? The highest reading in the mornings on initial start up never goes above 14.5V?
  • 2 months later...
I have the same problem with one or 2 it works fine with 3 i cant drop it below 15v and i have it on a switch and every time i turn it on it peaks at 16.3 and i have to re adjust it real quick befare it blows my computer or something. why is that nathan and why does it lose its memory each time? i wish it had a potentiometer or something so it stays at were you put it at. i just use it for comps cause it wont go below 15v and you said dont charge the batterys higher than 14.9
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
