Now i have this amp below for my mids its a 4 channel and i cant figure out how to make it HP not LP... im guessing it has to do with the tabs but i cant figure out what do do with them...
Edited by 55437Audio
My First Build on SMD (Blow Through)
2004 Ford F-350 SD Lariat
Pioneer 3200BT DVD Deck
Infinity Reference Components not powered
Bully Dog Gauge Cluster Pyro, Turbo, Trans
SF3 SCT Tuner W/Customs
If you can't Join em' Crush em'
i dont see any tabs...oh and fix that wiring a little bit. i see a straight exposed copper wire going to RF-. and i dont know why you are using the red 5v wires either...only wires you should be using for a PSU are green to adjacent black for turn on (on big 20 or 24 pin connector) and most if not all yellow wires with adjacent black wires for ground.
I'm not usi reds lol only the 2 yellow and 2 black from the power plugs. The red is taped off it's not done lol just through it together to get it working But your saying the green from the 24 pin would be better? Why? Aren't the yellows a true 12 v?
And there isn't any exposed wires going to any where in the amp actually.
green wire is turn on lead...nvm.
The tab are in between the RCA and the speaker terminals
those tabs are another form of inputs. they say high level inputs so i assume they arent crossovers.....
Ok on the bottom there is a sticker about hp and lp but I can't find where it's referring too
most likely your amp has a crossover card. its what RF used to use for their amps. its a little card with resistors on it that plugs into a slot on the board. you may or may not have said card.
