55437Audio Posted September 6, 2010 Report Posted September 6, 2010 (edited) Now i have this amp below for my mids its a 4 channel and i cant figure out how to make it HP not LP... im guessing it has to do with the tabs but i cant figure out what do do with them... Edited September 6, 2010 by 55437Audio Quote My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em'
DynamikT Posted September 6, 2010 Report Posted September 6, 2010 What tabs? I dont see no tabs. Are they on the other side? Most likely that old amp does not have a built in crossover, you'll have to buy a separate one. Quote
Guest Posted September 6, 2010 Report Posted September 6, 2010 i dont see any tabs...oh and fix that wiring a little bit. i see a straight exposed copper wire going to RF-. and i dont know why you are using the red 5v wires either...only wires you should be using for a PSU are green to adjacent black for turn on (on big 20 or 24 pin connector) and most if not all yellow wires with adjacent black wires for ground. Quote
55437Audio Posted September 6, 2010 Author Report Posted September 6, 2010 (edited) I'm not usi reds lol only the 2 yellow and 2 black from the power plugs. The red is taped off it's not done lol just through it together to get it working But your saying the green from the 24 pin would be better? Why? Aren't the yellows a true 12 v? And there isn't any exposed wires going to any where in the amp actually. Edited September 6, 2010 by 55437Audio Quote My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em'
55437Audio Posted September 6, 2010 Author Report Posted September 6, 2010 The tab are in between the RCA and the speaker terminals Quote My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em'
55437Audio Posted September 6, 2010 Author Report Posted September 6, 2010 L+ L- gnd R+ R- Quote My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em'
Guest Posted September 6, 2010 Report Posted September 6, 2010 I'm not usi reds lol only the 2 yellow and 2 black from the power plugs. The red is taped off it's not done lol just through it together to get it working But your saying the green from the 24 pin would be better? Why? Aren't the yellows a true 12 v? And there isn't any exposed wires going to any where in the amp actually. green wire is turn on lead...nvm. The tab are in between the RCA and the speaker terminals those tabs are another form of inputs. they say high level inputs so i assume they arent crossovers..... Quote
55437Audio Posted September 6, 2010 Author Report Posted September 6, 2010 Ok on the bottom there is a sticker about hp and lp but I can't find where it's referring too Quote My First Build on SMD (Blow Through) 2004 Ford F-350 SD Lariat Pioneer 3200BT DVD Deck Infinity Reference Components not powered Bully Dog Gauge Cluster Pyro, Turbo, Trans SF3 SCT Tuner W/Customs If you can't Join em' Crush em'
Guest Posted September 6, 2010 Report Posted September 6, 2010 Ok on the bottom there is a sticker about hp and lp but I can't find where it's referring too most likely your amp has a crossover card. its what RF used to use for their amps. its a little card with resistors on it that plugs into a slot on the board. you may or may not have said card. Quote
Playa Named Joe Posted September 6, 2010 Report Posted September 6, 2010 Doesn't look like there is a crossover on there... Quote 1994 Pontiac Grand Prix build
