Ok I called Parts Express Tc Sounds Dealer and asked questions about the LMS-R it says on the sheet DVC 2 Ohms per coil. So i asked him does the LMS-R come in DVC 4ohm So i could wire it down to a 1 ohm load. He says that "Impedance: 2 ohms per coil x 2 • RE: 3.96 ohms" is really 4 ohms per coil which is a DVC, which means that you could wire in parallel for a 2 Ohm load, or series for a 8 ohm load?? I looked at this page and listened to him and now im confused as fawk. What is the impedance of this sub, i thought i knew but i have no idea.... :shrug:
Here is the page with information
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=293-658
1 or 2 subs?
http://www.the12volt.com/caraudio/woofer_configurations.asp
if it says D2, its more than likely D2
that link will help you out so you can see it
Edited by Team_DC-Derrick
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
oo well i didnt realize you were running 2 woofers. then yes you are correct you would get a final of .5 if you parallel them all down.
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
two d2s wired in parrallel would be .5. tmo d2s wired in series would be 2ohms. what the man was trying to say is actual impedeance of woofer will read different. with meter. what amp do you plan on using?
Edited by dd98hoe
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
The Re* means both coils in series.
You have either a 1Ω load or a 4Ω per sub
So D2's is either 0.5Ω, 2Ω or 8Ω for the pair.
Yeah i was gonna run them in series for 2 ohms. But i'm really wanting to run two dvc 4ohms in parallel for 1 ohm load. I Was trying to ask him if they made them, but he told me i was looking at dvc 4 ohms. but they said dvc 2 ohms per coil
  • Who's Online   1 Member, 0 Anonymous, 848 Guests (See full list)
