I have an 01 Honda Accord and my rear deck shacks and rattles like crazy. Whats the best way to prevent that or at least help. It makes my system sound crappy and I can't stand it. So anything would be nice. Also, What kind of foam should I use to stop most rattling in the trunk lid and spoiler.
'01 Honda Accord EX 4 Cyl4/18/13
Started new build
Headunit: JVC kdx250bt
Sub Amp: Hifonics Hifi 2000d
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Wire: Knu 1/0 and 4awg
Big3:
What's wrong with peel and seal and spray foam if you want to go the cheap. Not as clean way?
My First Build on SMD (Blow Through)
2004 Ford F-350 SD Lariat
Pioneer 3200BT DVD Deck
Infinity Reference Components not powered
Bully Dog Gauge Cluster Pyro, Turbo, Trans
SF3 SCT Tuner W/Customs
If you can't Join em' Crush em'
you'll get mixed reviews on Peel and Seal. Some say it's not as durable and you need several layers to compare to one layer of Second Skin. I would use it on my floor in a heart beat though since you don't have to worry about it sagging down and it really is cost efficient.
peal n seal works wonders if your on a budget. I'd go peal n seal, some spray foam, and be done with it. I had the same issue in my 94 accord, doesn't rattle at all now :drink40:
put some p&S on the trunk lid. spray foam up in the bottom side of the package tray to get rid of the sheet metal noise. and you might try to P&S the front side of the seat rest. (The metal that the rear seat lays against) that really should cover it unless you upgrade the whole system...
Edited by superdave07
Xterra * 69 Camaro * Audi S5
36 Ford * 51 Mercury
looking for wire sponsor :)
www.flyracing.com
Well since im a college student funds are pretty tight. SO ima try out some P&S and spray foam. I can get all the at lowes right?
Started new build
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Big3:
Ya or home depot. Peel and seel I think are lil rolls of kinda thick paper that is sticky made by protecto wrap if I'm correct.
Edited by 55437Audio
How should I seal off my rear deck from the trunk? Just get a piece of wood, cut it to shape, and bolt it in?
Started new build
Door Amp:
Rear Amp:
Sub(s): SQ HDC3-12
Battery(s): Stock
Big3:
  • Who's Online   1 Member, 0 Anonymous, 1450 Guests (See full list)
