trading a earthquake dbx 12, and a box that ill be building tommorow for a RF 1000bd. can the be ran at 2 ohm mono? and the only thing wrong with this amp is the subs pop when you turn the radio on and off.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
so i get home and i hook it up and theres a loud high pitched humming noise, and the amp wants to go into protect very ver easy. gain is all the way down and bass and stuff on head unit is all the way down, IDK what is wrong with it, maybe my grounding point? was my first thought but ive used that same ground point with like 5 other amps and none of the noise ever.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
second tyhought was damn alternator wine, but my cables are on opposite sides, and dont think that would be it, any suggestions?
pics in a lil while
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
try a ground loop isolator and make sure the ground connection is secure and theres no rust, or paint between the conenction. and yes that amp is stable down to 2 ohm.
NoFearX18 said:
trainman0978 said:
Guest MegaloManiac
try to avoid the infamous ground loop isolator at all costs. See what you can do before getting 1 of those.
i think i may havwe my subs wired wrong, only other thing i can think that might cause it, to go into protect like it does.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
The amp can handle 1 ohm daily no problem - so as long as you are not going below that you should be good.
The amp also goes into protect to "protect" itself from shorts in the system. I'd check the woofers - meter them and make sure they measure good. Also chk the ground again and all of your wires.
An easy way to tell if it's the amp is to put another amp in it's place for a couple minutes and see what happens... if all is well then you know it's probably the amp.
