hagg555 Posted September 16, 2010 Report Posted September 16, 2010 is it possible to put 2 12 inch orion hcca subs in a ported box build to orion specifications with either 2 aq2200d or 2 hifonics HFi2500D amps with two to three batteries in my s-10 extended cab??
huh?do-what? Posted September 16, 2010 Report Posted September 16, 2010 mmm hmmm. God damn its hot today. My balls are stuck to my leg.
dugee81 Posted September 16, 2010 Report Posted September 16, 2010 Yep. Just gotta make space for everything. Every piece of equipment you plan on buying has measurements available before you purchase. So go out to your whip with measuring tape and go at it 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
cubs_fan0718 Posted September 16, 2010 Report Posted September 16, 2010 Yes it is possible, i had a buddy that had 2 15 hccas in a s-10 ext. cab. but he also only had them hooked up to some hcca cheater amps and those things wenrt very big at all. 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017
