will it affect anything if i take the covers off the amps so they can breathe better, any drawbacks with doing this. 2 DD M4"z
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
the bottom covers or the heatsinks?
the bottom covers will probably make the fan useless if it has one I know the m4a does not sure on m4
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
Top cover heatsink
MLA module 15+volts
Team Bass Hz
that will make it over heat in like 2 seconds flat and burn it up
the heatsink is there to dissipate heat lol.
why remove it?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
I wanted to take them off & put a couple of Stinger fans on them
MLA module 15+volts
Team Bass Hz
The Stinger 8" cross-flow fan is what i had in mind, but from what u guys think it doesnt sound like it will work
MLA module 15+volts
Team Bass Hz
no it will over heat bad even with a fan
you could put the fan so it pulls the heat off the sink that might help but do not take the heat sinks off
Ok thanks for the info
MLA module 15+volts
Team Bass Hz
id put the fans on the back plate.
take you a die grinder or some sort of metal cutting tool and cut you out a little sqaure for it or something to mount them on.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
  • Who's Online   0 Members, 0 Anonymous, 1027 Guests (See full list)
