amplifier 2 run 4 eight inch
hello people i ned some suggestions i have 4 eight inch midrange speakers rated at 350 wrms a piece my problem is i need an amplifier that can deliver at least 1400 wrms @2 ohms and i will bw running 14 volt batteries so i will be charging at 16 volts minimum any suggestions to a good amp will be welcomed thanks guys....
What frequency range do you need to play? A lot of the Stetsom and Soundigital amps (not 100% on SD?) play up to like 14khz and will deliver that kind of power.
10.x volts fo' life!
  • Who's Online   1 Member, 0 Anonymous, 1053 Guests (See full list)
